Activity Forums Adobe After Effects Expressions Looping Source Text held keyframes
  • Looping Source Text held keyframes
    Posted by Thomas Hannen on July 22, 2011 at 3:57 pm
    Is there any way to loop around (e.g.) four Source Text keyframes?
    I’ve tried
    loopOut(type = "cycle", numKeyframes = 4);
    Which normally works for normal linear keyframes (e.g. as Position or Rotation keyframes), but when applied to Source Text, it gives:
    Function loopOut is undefined
    Many thanks,
    Tom
    Jacek Fischer replied 5 months, 2 weeks ago 4 Members · 3 Replies
  • Kevin Camp
    July 22, 2011 at 4:21 pm
    that’s interesting… i’ve never tried to loop source text keyframes (or hold keyframes, for that matter), but you’d think it would work like any other keyframes….
    this does seem to work, but you’ll need to add another ‘dummy’ keyframe as the last keyframe:
    valueAtTime(time%key(numKeys).time)
    it assumes you want to loop all keyframes, but to have the your current last text value be included, you’ll need to add a dummy keyframe at the point where you want it to start to loop.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Davi Herold
    January 11, 2017 at 8:41 pm
    Ok, so I know this is an old post, but this occured to me only recently, and I would like to leave a comment in here just in case someone else gets as stuck as me again.
    Short answer, you can’t do that.
    “You can use keyframe-looping methods to repeat a series of keyframes. You can use these methods on most properties. Exceptions include properties that can’t be expressed by simple numeric values in the Timeline panel, such as the Source Text property, path shape properties, and the Histogram property for the Levels effect.”
    https://helpx.adobe.com/after-effects/using/expression-language-reference.html
    Sorry, but as of yet, I have not found a work-around.
    Cheers,
    Davi.
  • Jacek Fischer
    March 26, 2026 at 7:54 am
    I know it’s terrible archeology 😉 but if someone had a similar problem – you can use a text box with many lines and set keyframes to position and thus jump between specific lines – a solution known from websites as a sprite sheet.
