Activity Forums Adobe After Effects Expressions Looping sound by markers
  • Steve Roberts
    January 1, 2006 at 6:22 pm
    You could try this:
    1. Add markers (* on the numeric keypad) to the footage layer, indicating where each footstep occurs
    2. Apply time remapping to your “single-footstep” audio layer.
    3. Extend the out-point of the audio layer to the end of the comp.
    4. Convert the second keyframe to a hold keyframe (right-click on the keyframe and select “toggle hold keyframe”)
    5. Move one frame to the right and scrub the time-remap value (drag the value with the mouse) so it reads 0. This will “rewind” the playback of your sound to the beginning.
    6. Select these 3 keyframes and Copy them.
    7. Move to the next frame where the footstep occurs and Paste the 3 keyframes. Do a RAM preview to test.
    8. If it works, go ahead and Paste the 3 keyframes where each footstep occurs (at each marker).
    I just tried this, so it works. 🙂
    If the footstep sound is too long for the time available between footsteps, you may need to create 2 footstep audio layers: one for the left foot, and one for the right foot.
    Good luck, and Happy New Year!
    Steve
  • Filip Vandueren
    January 1, 2006 at 9:37 pm
    Here’s the expression-way:
    4. Give the time-remapping property of the sound-layer this expression:
    l=thisLayer; // change this to the layer that has the markers. just select 'thisLayer' and then pickwhip to the layer.
    t=0; i=0;
    if (l.marker.numKeys) {
    m=l.marker.nearestKey(time);
    i = m.index-((m.time>time) ? 1 : 0);
    t= (i==0 ? 0 : l.marker.key(i).time);
    if (i>0) {
    time-t;
    That should do the trick.
    If you actually apply the markers to the Audio-layer, you don’t need to change the first line of the expression.
  • Filip Vandueren
    January 2, 2006 at 12:41 am
    Just a quick repost, because the comment in line 1 wrapped after posting: that would have given errors.
    to recap:
    use this code on the audiolayer,
    if you have the markers on another layer, change the first line.
    l=thisLayer;
    t=0; i=0;
    if (i>0) {
    time-t;
    Steve’s suggestion of using 2 different footsteps is a good idea BTW.
  • Mike Clasby
    January 3, 2006 at 8:58 pm
    Wow, that is great stuff, thanks mucho.
