Activity Forums Adobe After Effects Expressions Looping part of a precomp, then playing the rest
  • Looping part of a precomp, then playing the rest
    Posted by Rob Womack on February 22, 2017 at 8:56 pm
    I have a composition that contains a precomped animation (38 frame duration) that I want to loop from the start to 12 frames until I am 26 frames from the end of the layer, then I want to play the rest.
    I have my precomp in layer 1, time remapped with two keyframes (0 and 11). I have the following expression applied to the timeRemap property:
    i = this;
    if (i.effect("Ladder")("Checkbox") == 1) {
    duration = timeToFrames (i.outPoint - i.inPoint);
    layerIn = timeToFrames(i.startTime + thisComp.displayStartTime);
    layerOut = layerIn + duration;
    currentTime = timeToFrames(time + thisComp.displayStartTime);
    trigger = timeToFrames(i.source.duration + i.source.displayStartTime - i.sourceTime(i.timeRemap.key(2).time))
    remainingFrames = layerOut - currentTime;
    elapsedTime = currentTime - layerIn;
    if (remainingFrames > trigger) {
    remapVal = elapsedTime % (timeToFrames(i.sourceTime(i.timeRemap.key(2).time)) - timeToFrames(i.sourceTime(i.timeRemap.key(1).time)))
    else {
    remapVal = timeToFrames(i.sourceTime(i.timeRemap.key(2).time)) + (trigger - remainingFrames)
    framesToTime(remapVal)
    Two goofy things right off – I am setting the variable i to this, and am switching back and forth from frames to time, because I copied and pasted the code from a text layer to see what was happening. When I apply the expression to the text layer’s text property and make i = to the precomp layer, it works. When I apply to the precomp layer, once it hits the trigger it defaults to the duration of the precomp source layer, basically a blank screen.
    There’s probably a better way to do this, but the loopOut always starts from the 1st keyframe, and I want to start from the 2nd keyframe and play to the end. Any help would be appreciated.
    Robert Womack
    Creative Bridgekeep
    http://www.CurrentMarketing.com
    “Louisville’s Leading Interactive Marketing Agency”
    Rob Womack replied 9 years, 6 months ago 2 Members · 2 Replies
  • Kevin Camp
    February 23, 2017 at 7:50 pm
    the tricky part is your loop needs to start from 11 frames in and work backwards so that it will time correctly with the continuation…
    an easier solution (expression-wise) would be to use the loopInDuration() function to loop the initial 11 frames coming into the time remapping keyframes, then play out as normal.
    try this on your time-remapped layer:
    loopPoint = 11; // value in frames
    loopInDuration( 'cycle', framesToTime( loopPoint ) )
    then you’d need to slide that layer along the timeline to where you want it to finish the animation, and then simply extend the in-point as needed.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Rob Womack
    February 24, 2017 at 2:29 pm
    That worked! Thanks.
    I figured I was making three lefts to take a right, but the loopIn, loopInDuration and loopOut functions confuse me, for some reason.
    Robert Womack
    Creative Bridgekeep
