Activity › Forums › Maxon Cinema 4D › Looping issue
  • Looping issue
    Posted by Will Hagen on June 2, 2023 at 12:29 am
    I’m having some issues getting some projects to loop correctly. I’m using R21 still and wondering if it might have anything to do with that although I can’t see why some things would loop perfectly but not others. One project loops perfectly until I use the delay effect then there is a jump at the last frame. Another project I use forester and can get a tree with wind to loop perfectly with no issues but if I try to do the same with the multi flora again I get a jump at the end. I understand whole frame numbers thing about dripping the last frame etc so it’s not a lack of understanding about how loops work. I’m wondering if it’s a bug? Or is it a setting I’m missing somewhere? I can’t see why using an older version would cause this issue as I’ve used it for a long time and never run into this until now. Would it possible for someone to take a look at my project and see where I might be going wrong and if the problem duplicates in their version? Thank you
    Kouraib Abdmalek replied 3 years, 2 months ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    July 6, 2023 at 7:06 pm
    Hi Will Hagen, you can send me the project file so I can take a look and make sure the cause of the problem
