Activity › Forums › Adobe After Effects › Looping in Trapcode Particular
Posted by Darren Lee on October 6, 2021 at 11:29 amI’ve searched for a way of doing this, but it seems the only way is to duplicate the the layer and do a fade into the start of the current one
I am surprised there is not an easy way to do this in TP. In Cinema 4d noise you just check the ‘loop’ parameter
John Martin replied 11 months, 3 weeks ago 5 Members · 6 Replies -
Graham Quince
October 6, 2021 at 12:10 pmWhat are you trying to loop? Almost all of Particular’s properties can be keyframed, which should let you loop them
Darren Lee
October 6, 2021 at 12:24 pmWell they have to ‘birth’ don’t they? So you’d have to start from a few seconds in
Also the physics, ‘Twirl’ etc.. aren’t keyframes
Thanks for your reply
Michael Szalapski
October 6, 2021 at 1:21 pmIf I want to loop particles with Particular, I just keyframe away the particles per second. So I have a start and an end. Then I just take that clip, split it in the middle and move the clips so that the middle split part is now the beginning and end and I overlap the old beginning and end (now the middle) where the particles start and stop so that they seem to mix together.
Bam. Seamless loop.
Darren Lee
October 6, 2021 at 1:33 pmYes that’s what all the tutorials I’ve googled say, I was wondering if there was a simpler solution, but thanks for confirming!
Alonso Magaña
September 13, 2025 at 11:38 pmPutting the random seed and all velocities to zero is an start for a simple system. Add a little bit of gravity and your animation will had a seemless loop at some point. From there you can start playing with other parameters.
John Martin
September 14, 2025 at 3:46 pmhey Darren this is your lucky day, just send me a video example of what you mean by “looping” and i’ll send you a unique tutorial with a custom solution that will solve with a simple, powerful and unexpected technique, talk soon! 🔥
