Activity Forums Boris FX Particle Illusion Looping in PI does not work!
  • Looping in PI does not work!
    Posted by Klewe1 on October 16, 2005 at 10:47 pm
    Hello there,
    I have a problem in looping a film. I used the tutorial on the page and it works fine. The only problem I have is that on the layer 0 I cannot set the sequence to Start: 1 and End: 76. Everytime I put in these settings the computer automatically changes it to: Start: 1 and End: 150.
    What I’m I doing wrong?
    Please help, I really need the movie I am making.
    Thanks alot
    Mike
    Klewe1 replied 20 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Airwolf
    October 17, 2005 at 4:54 pm
    Mine does the same thing but the loop still works for me.
  • Klewe1
    October 17, 2005 at 8:21 pm
    Mine loops fine in the beginning, but it does the same in the middle of the movie (where I change from one frame to the other) like it did in the beginning when I had no looping at all.
    Anny help would be appreciated.
    Klewe
  • Klewe1
    October 19, 2005 at 9:25 pm
    I really need this. Anyone who can help me? Please…
    klewe
  • Alan Lorence
    October 19, 2005 at 9:57 pm
    There is a bug in the Background Image dialog that always shows the “end frame” as the last frame in the sequence. If you change it to a lower value and click OK, the value will be used.
    When you open the dialog again, it will show the wrong value, and I think you need to change it again to whatever value you need.
    Alan.
    wondertouch
  • Klewe1
    October 19, 2005 at 10:28 pm
    I tried that too, but it keeps not to change right in the middle of the film. When it changes from a layer to the other you see decrease the visibility. At the end (frame 150) it loops fine. What’s the matter?
    klewe
  • Alan Lorence
    October 19, 2005 at 10:35 pm
    Make sure you’re using the latest version. Check the downloads page for updates.
    I’m not seeing the problem that you are, unless I just don’t understand it.
    Can anybody else duplicate this problem?
    Alan.
    wondertouch
  • Klewe1
    October 20, 2005 at 7:02 am
    Here is what I have done:
    – Made the video by reducing the number and visibility to zero at the end of the movie. Saved the sequence to pngs.
    – then made a new movie creating a new layer (layer 1 below layer 0). Inserted background with parameteres shown in the tutorial.
    – the same on layer one.
    Should I do something else?
    Klewe
