Looping a property that already has an expression
I’m using the really fantastic Ease and Wizz script from Ian Haigh that gives you more option in how values in between keyframes are interpolated.
I’ve contacted the author and there doesn’t seem to be an easy way to add a looping option in the code.
So, I’m coming for the expertise of Dan to see if he can make this expression loop (both normal and ping-pong)
If the code to too unwieldy to unravel, what about linking this expression to a Point Control effect (for 2D position) or slider (for 1D effects) and then adding a simple loop_out(); to those controllers?
// Ease and Wizz 2.1 : inOutExpo : All keyframes
// Ian Haigh (https://ianhaigh.com/easeandwizz/)
// Last built: 2009-12-30T13:08:29+11:00
// some defaults
var p = 0.8; // period for elastic
var a = 50; // amplitude for elastic
var s = 1.70158; // overshoot amount for "back"
function inOutExpo(t, b, c, d, a, p) {
if (t==0) return b;
if (t==d) return b+c;
if ((t/=d/2) < 1) return c/2 * Math.pow(2, 10 * (t - 1)) + b;
return c/2 * (-Math.pow(2, -10 * --t) + 2) + b;
function easeAndWizz() {var n = 0;
if (numKeys > 0) {
n = nearestKey(time).index;
if (key(n).time > time) { n-- }
try {
var key1 = key(n);
var key2 = key(n+1);
} catch(e) {
return null;
}// determine how many dimensions the keyframes need
var dim = 1; // It's gotta have at least ONE dimension
try {
key(1)[1];
dim = 2;
key(1)[2];
dim = 3;
} catch(e) {}
t = time - key1.time;
d = key2.time - key1.time;
sX = key1[0];
eX = key2[0] - key1[0];
if (dim >= 2) {
sY = key1[1];
eY = key2[1] - key1[1];
if (dim >= 3) {
sZ = key1[2];
eZ = key2[2] - key1[2];
if ((time < key1.time) || (time > key2.time)) {
return value;
} else {
val1 = inOutExpo(t, sX, eX, d, a, p, s);
switch (dim) {
case 1:
return val1;
break;
case 2:
val2 = inOutExpo(t, sY, eY, d, a, p, s);
return [val1, val2];
break;
case 3:
val3 = inOutExpo(t, sZ, eZ, d, a, p, s);
return [val1, val2, val3];
break;
default:
return null;
(easeAndWizz() || value);
