Activity Forums Adobe After Effects Loop virtual set
  • Loop virtual set
    Posted by Gene Weglarz on August 3, 2013 at 8:35 pm
    Ok I feel like this a stupid question, but I can’t find an answer anywhere.
    I have some ten second virtual set clips. I need to loop them for two minutes. It seems this should be a simple thing to do.
    Geoffrey
    Gene Weglarz replied 13 years, 1 month ago 2 Members · 3 Replies
  • Darby Edelen
    August 3, 2013 at 10:15 pm
    There should be a field in the Interpret Footage dialog that allows you to specify the number of times you’d like the footage to loop. This dialog is accessible in the context menu if you right click the footage in your project panel.
    The other option is using Time Remapping and the loopOut(); expression. I’d recommend researching that before using it.
    Darby Edelen
  • Gene Weglarz
    August 4, 2013 at 1:31 pm
    I’ve looked there but there is no option for loop. The “more options” button is greyed out.
    Geoffrey
  • Gene Weglarz
    August 4, 2013 at 1:34 pm
    Oops, just found it. Thanks that works perfect.
