Activity Forums VEGAS Pro Loop Regions
  • Loop Regions
    Posted by Bob Hobart on August 1, 2012 at 10:07 am
    Practically every time I click anywhere on the time line or indeed anywhere on the screen, a loop region of varying lengths is created – most annoying.
    I appreciate there is an old thread on this issue and in response to a similar inquiry, Mike Kujbida suggested enabling ‘Options – Prefs – Editing – Collapse loop region when no time selection is present’. I have done this however it does not seem to have any effect.
    Could anyone suggest what I might be doing wrong? I’m using Vegas Pro 11.
    Matt Crowley replied 14 years, 1 month ago 3 Members · 4 Replies
  • Roger Bansemer
    August 1, 2012 at 12:23 pm
    Uncheck the icon towards the bottom left. It’s the one that looks like a circle with an arrow on the end. That’s the loop button.
    Roger Bansemer
  • Matt Crowley
    August 1, 2012 at 7:14 pm
    Is the loop region thing actually causing you problems? If not, then don’t worry about it – it’s standard behaviour for Vegas and doesn’t actually affect most tasks.
    If you really are managing to create timeline selections with just a single click (and even outside the timeline) then either you’ve found a very weird bug, or your mouse is doing double slicks or the shift key is stuck or something like that.
  • Bob Hobart
    August 5, 2012 at 5:14 am
    Thanks to Roger and Matt re problems with loop regions. Incredibly, my problem was a dud mouse. Swapped it out with a new one and bingo, loop regions feature now behaving as it should. Many thanks.
  • Matt Crowley
    August 6, 2012 at 5:22 pm
    Aha! I had a mouse that occasionally did double-clicks and all sorts of weird things happened. I was able to swap the microswitch inside for one from an old mouse and that fixed it.
