Activity Forums VEGAS Pro Loop playback DVD
  • Loop playback DVD
    Posted by Dom Domineaux on March 20, 2009 at 4:13 am
    I need to produce a DVD of some photos that will loop cycle the video on Blue Ray DVD in HD.
    The DVD architect worked, but it was in 720×480 resolution only.
    I need this in 1920×1080 like my Sony HDRSR12 records it. The format my camcorder uses is AVCHD.
    I called SONY for support and got some gal East of Pakistan, and couldn’t understand her. So, I just gave up.
    Can I do this from Vegas Pro 8.0/8.1?
    I can render the 1920×1080 from vegas, but I have not been able to find out to make the DVD with the timeline repeating. (looping photos)
    I sure hope I explained this. I could sure use some help on this.
    John Rofrano replied 17 years, 6 months ago 3 Members · 2 Replies
  • Graham Bernard
    March 20, 2009 at 12:49 pm
    If it is the same as DVD authoring then use the “End Action” option to play the same Chapter or sequence again and again until you hit Menu. OR, if Blu Ray players have an A<>B option to loop on the zapper do it that way?
    Grazie
  • John Rofrano
    March 20, 2009 at 3:16 pm
    I assume you want to make a Blu-ray disc and burn it to DVD media, yes? This may or may not work out well depending on your Blu-ray player. Mine (Samsung BD-P1400) stutters when playing AVCHD Blu-ray burned to DVD media. Your mileage may vary.
    That’s because the DVD format is 720×480. You want to start a Blu-ray project in DVD Architect. Then burn that to DVD media.
    As Graham pointed out, set the end-action of the video in DVD Architect to jump back to the beginning.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
