Looks like there’s an update to SVP 12–Build 765
Posted by Ron Whitaker on November 20, 2013 at 12:55 amDownloading now!
Steve Rhoden replied 12 years, 10 months ago 12 Members · 20 Replies -
Graham Bernard
November 20, 2013 at 7:42 amBeen “bashing” it for an hour now. Render times look good. I applaud the SCS team for getting the Drag Chains from Plug-In Manager directly to event without crashing. I have the best part of 350 Chains within Plugin-Manager laid out in 3 Folders, I’ve just spent a delightful time dragging and dropping-off all sorts of chains from the 3 Folders into 29.970 fps progressive, 640x480x12, AVC, Events and all is presently solid as a rock. I shall now get back to my “usual” formats and try on them too.
Just rendered a 10 iPhone 29.971 fps progressive, 1280x720x12, AVC TO Lagarith AVI 1:30min project and it took 12 minutes of 10 Track
2xTracks of Particle Illusion
2xTracks of the iPhone AVC with Invert and complex Colour Correction and Grading.
1xTrack of NewBlue Titler Pro
1xTrack of complex GenMed
3xAudio Tracks with Elastique slow-down.
1xAudio Track iZo Ozone
Looking good.
Grazie
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Roger Bansemer
November 20, 2013 at 11:48 amWhat exactly is new with the update?
I’ve been out of touch for a while.
RogerRoger Bansemer – PaintingAndTravel.com
Mike Kujbida
November 20, 2013 at 11:51 amNotable fixes/changes in version 12.0 (Build 765)
Added support for MOV files when exporting to Media Composer AAF format.
Added support for writing sidecar XML files when rendering XAVC and XAVC S video.
Added templates for rendering Sony XAVC / XAVC S video.
When rendering XAVC S files, audio is now rendered in LPCM format.
Fixed a bug that could cause a crash when rendering a project that contained an empty metadata command marker.
Fixed a bug that could cause a crash when using Tools > Multicamera > Create Multicamera Track with an empty track selected.
Fixed a bug that could cause a crash when importing 1440×1080 XAVC files.
Fixed a bug that could cause a crash when dragging a preset chain (filter package) from the Plug-In Manager to an event, track, media file, or the video output.
Fixed a bug that could cause a crash on some systems with NVIDIA graphics when reading 4:2:0 480p widescreen media.
Fixed a bug that could cause Vegas to freeze when adding some interlaced MP4 videos to the timeline.
Fixed a bug that could cause rendering to hang when rendering to XDCAM EX MP4 files with the Enable no-recompress long-GOP rendering check box (Preferences > General) selected.
Fixed a bug that could cause .aaf files imported from Media Composer to be read using an incorrect frame rate in Vegas Pro.
Fixed a bug that could cause .mov and .mp4 files imported from Media Composer to be read using incorrect timecode in Vegas Pro.
Fixed a bug that could cause a hang when rendering 4K XAVC S video on some computers.
Fixed a bug that could cause an error to be displayed when importing and MXF file from an Optical Disc Archive unit.
Fixed a bug that could cause Vegas Pro to hang when reading MP4 video from the GoPro Hero 3+.
Fixed a bug that added a green bar when reading 480p widescreen AVC files.
Fixed a bug that prevented Vegas Pro from updating the file size estimate when Render Loop Region Only was selected during Blu-ray Disc burning.
Fixed a bug that prevented Sony F5 cameras from playing XAVC HD 23.98p clips rendered in Vegas.
Fixed a bug that caused the Iris transition to reverse A- and B-roll video when GPU acceleration was turned off.
Fixed a bug that prevented Vegas from correctly reading SD MP4 clips that were shot in portrait mode.
Fixed a bug that prevented Vegas from persisting the View transform setting on the Video tab of the Project Properties dialog. -
Angelo Mike
November 20, 2013 at 8:17 pm -
Bob Peterson
November 20, 2013 at 9:09 pmAll I see is build 726 on your link. Any idea why I’m not seeing 765?
Mike Kujbida
November 20, 2013 at 9:41 pmBuild 765 is no longer available on the Sony site so they must have pulled it due to several complaints on the Sony Vegas forum.
Mike Kujbida
November 20, 2013 at 11:22 pmThis was very recently posted to the Sony Vegas forum by Chris Dolan from Sony.
765 was pulled after QA verified the MainConcept GPU render issues reported in this thread. Adding support for LPCM audio in the CPU code (as opposed to AAC) accidentally left the GPU code without any audio codec selected so it bailed out. The jump back to frame 0 that some of you saw was Vegas trying to recover in CPU mode, but still without any audio codec selected.
The fix looks simple (auto-select AAC for the GPU modes) so I predict a new update soon but please don’t hold me to that because it’s not my call! -
Graham Bernard
November 21, 2013 at 8:20 amI also commented that I was getting ZERO frame jump back on Render to the SONY MP4 encoder. However, the rendered file “appeared” ok for my purposes.
I can only applaud SONY’s new fresh approach to these quick responses and turnarounds on Vegas Pro. If they keep this vigilance tied-in to urgency going, then the future of Vegas Pro is looking good. They did this not long ago with the pulling of a build due to the Image Sequence going AWOL. In that instance the replacement BUILD was done in a handful of days.
So, Kudos where it’s due – yes?
Cheers
Grazie
Steve Rhoden
November 21, 2013 at 10:15 amYeah, its been pulled. A renewed version soon i hope.
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
https://www.facebook.com/FilmexCreativeMedia
1-876-461-9019
