Looking to subtract between two images & add the difference to another
Hi all,
I have some footage that has a strange banding effect — wide bands of light and dark very slowly moving up the image. It’s regular and consistent, and there is a part of the image that doesn’t move at all, so I would like to freeze frame that part, grab the difference between the freeze frame and the current frame, and then apply that difference, inverted, back to the image.
I’m playing with blend modes and precomps, but the issue is that things like the subtract mode clip values and don’t act perfectly. Is there a plugin that lets me do arithmetic blending of images?
Here are some screenshots of my project:
The original image:
https://www.dropbox.com/s/xscr4qeaiumhln2/Screenshot%202014-02-16%2014.13.09.pngA precomp, with the unmoving section cropped out (and a blur):
https://www.dropbox.com/s/pu87vnnzzic5057/Screenshot%202014-02-16%2014.14.19.pngThe freeze frame applied over the precomp, blending mode set to subtract, and another blur applied. I’ve used the Levels effect to expand it and see the difference — in reality, the values are around 1% brightness
https://www.dropbox.com/s/st2t5ietjdrfe2z/Screenshot%202014-02-16%2014.16.44.pngA split-screen of the extended precomp on top of the image:
https://www.dropbox.com/s/qdh81bbbunvsg8j/Screenshot%202014-02-16%2014.17.12.pngThanks all!
Michael
