Activity › Forums › Adobe After Effects Expressions › Looking to create a 3D neon sign
Posted by Miro Segura on July 7, 2006 at 5:36 pmHi there,
I’m looking to create a 3D neon sign and not sure where to begin. Any suggestions? Is there a simple 3D program or can I create it all in After Effects.
Any help is much appreciated,
Miro
Dan Asselin replied 20 years, 2 months ago 5 Members · 4 Replies -
Edward M
July 7, 2006 at 7:35 pmIt all depends on what you consider simple.
There is Zaxworks 3d invigorator that alot of people I know use when they need a quick 3d object in AE.
I personally use 3DS Max to create all my 3d and render seperate layers so I can add glows to what I want and so on. that way my neon glows a little and my clients like it.
It just depends on how deep you want to get into a simple 3d sign.
Eddie -
Vince Becquiot
July 7, 2006 at 10:45 pmThe simplest way would be using Trapcode 3D Stroke. But how realistic you want it to be is always the question.
Vince
Sam Moulton
July 8, 2006 at 11:51 pmgo to trapcode-people.net and look or search for neon. I think it works very well. I’ve even tried the glow technique with strokes on regular layers so you can use the style without 3d stroke
Dan Asselin
July 9, 2006 at 3:05 amI also used a small expression on the brightness to give me a flickering effect like an old neon sign. Use something like
“random(1,50)” (That may not be exactly right) and you’ll find it much more realistic. I also managed to find a neon font which really helped. Dan
