Activity › Forums › VEGAS Pro › Looking to combine Generated Media and Event FX automatically in Sony Vegas Pro 12
Mike Yoneda replied 13 years ago 2 Members · 16 Replies
Mike Yoneda
August 12, 2013 at 8:42 amAppreciate all the help.
Aloha,
Mike Yoneda
High Angle Video
Mililani, HI -
Graham Bernard
August 12, 2013 at 8:46 amWill you use this approach?
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Mike Yoneda
August 12, 2013 at 9:02 amFor now, since I need to get a job done, I will go with the copy and paste method and just use the keyframe to do the tracking.
Once I complete that job, I will experiment with your suggestion.
In the past, when I used either the pan and crop or the track motion, it was applied across the entire track. That was a long time ago so I might be mistaken. With your suggested method, can I do either of your two suggested methods for each individual clip while still keeping just two tracks, one for the highlight events and one for the media clips?
Lastly, am I able to save the combined event so that I can easily access it when opening a new project or do I have to manually insert the two saved presets the first time for a new project, then do the copy and paste method?
Mahalo,
Mike Yoneda
High Angle Video
Mililani, HI -
Graham Bernard
August 12, 2013 at 9:38 amTrack Motion is applied to the Track. Pan/Crop is applied to the Event.
G
Graham Bernard
August 12, 2013 at 9:54 am[Mike Yoneda] “Lastly, am I able to save the combined event so that I can easily access it when opening a new project or do I have to manually insert the two saved presets the first time for a new project, then do the copy and paste method?”
_______________________________________________________________
Yes, it’s a Vegas Project, like any other you would save. You can save the Combo Event within something called Soccer Combo Event.veg, use it with NEW footage and save as another name.
Cheers
Grazie
Mike Yoneda
August 13, 2013 at 7:57 amI am interested in using one of your techniques but I don’t have much experience using either. If I have multiple clips and I need to have the size of the oval vary due to player size, so I be using the track motion or pan/crop?
For example, I may have 50 clips and I will be copying the combo event in the same video track overlay. Each combo event may need a slightly different oval size due to zooming of the raw video. Once I set the size of the oval for a specific combo event, which technique should I be using and how do I “animate” the movement of the oval for the short interval to highlight the player?
Mahalo,
Mike Yoneda
High Angle Video
Mililani, HI
