Activity › Forums › Adobe After Effects › Looking for Video shatter fx, particle fx ,title fx plug ins for After Effects… templates available
  • Looking for Video shatter fx, particle fx ,title fx plug ins for After Effects… templates available
    Posted by Bruce Klein on March 22, 2014 at 3:38 pm
    I am looking for a plug in shatter effect to transition video. Ex: Image 1 shatters (particles)That fly of the screen and transition to Video Image 2.
    I am unfamiliar with after effects and I hope to find something to plug in or a template to use. To create it myself in AE may take me days when I have a few minutes to dedicate to this…
    I understand that I am at fault for not learning this program. I need a easy and fast solution.
    There is so much software out there I am also confused as to what to buy, how to use it or if I need to by it. So I think the template is the way to go
    Franky I do not even have the knowledge on how to use a pre created template or plug in effect.
    I am also looking for an easy title animation templete plug in pre made effect file to use.
    Any information and direction to products and tutorials would be would be greatly appreciated
    I use Adobe Premiere Pro CS 5.5 on a IMAC 27, Intel core i5 2.7 GHz, 12 GB 1333 MHz DDR3… MAC OSX 10.6.8 I have a 2 2 Terabyte external drives also.
    Thanks in advance for your help.
    Bruce
    John Cuevas replied 12 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • John Cuevas
    March 22, 2014 at 8:52 pm
    I strongly recommend, Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC).
    But if you are painted in a corner, here is a very simple shatter transition project, all you need to do is put video in the “Image 1” comp. In the image 2 comp, you will put your second video, right click the layer, go to Time > Time Reverse Layer. Press End, the press the “]” so that the start of your clip is now at the end of the comp. Then render the “Shatter Transition” comp.
    7278_shattertransitionfolder.zip
    As far as logo transitions, there are pretty inexpensive templates you can purchase at; revostock,
    video hive.net(one word), pond5, envanto.com
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Bruce Klein
    March 23, 2014 at 3:59 pm
    John… Thanks for your reply. I am on a Mac and the file you were kind enough to send me is a Windows file…
    ABK
    Bruce
  • John Cuevas
    March 23, 2014 at 4:17 pm
    An AEP file will open on a Mac or a PC, are you on a version pre-CS6? Cause I can create a legacy version back to CS5.
    Thinkck.com
  • Bruce Klein
    March 23, 2014 at 4:27 pm
    CS 5.5 thanks. I still need to. Figure out how to even use a template.
  • John Cuevas
    March 23, 2014 at 5:26 pm
    Here you go. Just follow the instructions above and it will work for you.
    7281_shattertransitioncs55.zip
    Thinkck.com
  • Bruce Klein
    March 24, 2014 at 1:18 pm
    Any chance you can send the file for CS 5.5?
    Bruce
  • John Cuevas
    March 24, 2014 at 2:44 pm
    I did, it was in the link above your last post, but here it is again: 7281_shattertransitioncs55.zip
    Thinkck.com
