Activity Forums Avid Media Composer Looking for recommendations for Avid full screen monitor
  • Looking for recommendations for Avid full screen monitor
    Posted by Sean Lewis on February 18, 2020 at 11:18 pm
    Hey there,
    I am looking to buy some gear for a home setup with Avid MC.
    One thing the post facilities I’ve worked at in the past have mentioned, is that it can be difficult to find a computer monitor for full-screen playback that will work on 24p and 25p projects.
    I’m talking about the monitor that will be connected via HDMI and a blackmagic converter.
    Does anyone know what specs you need to look out for when shopping for this? Eg Vaults, Hertz, etc?
    Another option is to get a TV, rather than a computer monitor. I’ve been told this can solve the problem, but it means you’re less likely to find a solution with an adjustable height neck, like computer monitors do.
    Any advice would be really appreciated.
    Eric Santiago replied 6 years, 7 months ago 2 Members · 3 Replies
  • Eric Santiago
    February 19, 2020 at 3:39 pm
    I use an Eizo CG277 via BMD U4K HDMI from a 2013 Mac Pro and HP Z840 at home.
    At work, a Flanders LMD 24″ via Avid Artist DNxIO HDMI from a 2013Mac Pro.
    Both displays are great for the price we got them.
  • Sean Lewis
    February 20, 2020 at 4:46 am
    Thanks Eric.
    Have you tested both these setups for full screen playback on 24p and 25p projects?
  • Eric Santiago
    February 20, 2020 at 4:58 pm
    [Sean Lewis] “Have you tested both these setups for full screen playback on 24p and 25p projects?”
    Only NTSC 29.976 and Film 23.976.
    I’m in North America.
    I am confident it will handle 25p.
    What is it that concerns you?
    Also to add, the work setup has Avid output to a Sonny 65″ XBR 4K.
    It’s a lovely display 🙂
