looking for quick way to compare “snapshots” of a cut
I am working on a project with lots of quick transitions and cuts with multiple tracks involved and I would like to quickly compare different versions where transitions are just moved around by a few frames or sometimes a clip is swapped.
Is there something like a “snapshot” feature in Premiere that lets me easily save or temporarily store a version of a small portion of the timeline and then compare it to a different version? If not… can someone suggest a workaround that gives me the same result?
It’s important that it is fast and gives me the ability to compare several temp versions on the fly.
If there is no solution inside of Premiere available I’d also try out something else that will give me the same result.
