Activity › Forums › Adobe After Effects › looking for gunshot effect..
Posted by Frank Mixson on August 4, 2005 at 8:25 pmHi there,
I’m looking for a tutorial, or something, to help me create a gunshot effect,from a 9mm, with camera facing side of gun (barrel points stage left or right).
Any help will be greatly appreciated
Thank you
Frank Mixson
Frank Mixson replied 21 years, 1 month ago 6 Members · 6 Replies -
Colin Braley
August 4, 2005 at 8:37 pmI’m pretty sure there is a plug in called muzzle flash allthough I can’t remember who makes it. This plug in can make the flashes that are emitted from the front of guns. If buying a plug in is out of the question you could try taking some fractal noise and colorizing it, then adding a mask to it so it appears in front of the gun. You could then animate the mask shape to make the flash grow and recede over a few frames.
~Colin -
Jeff Mullen
August 4, 2005 at 10:03 pm -
Mike Clasby
August 5, 2005 at 2:37 amHere’s a great freebie site, even comes with tuts for compositing the free footage they give you:
https://www.detonationfilms.com/free_stuff.htm
Particle Illusion also has some nice muzzle flashes, even with casings flying out ala automatic/machinegun. Go ask at the PI Forumn here at the Cow. I forgot which month had the muzzle flash particles. There is the PI SE version, 30 days fully functional free trial. PI hopes to soon have an AE plugin.
Graham Quince
August 5, 2005 at 7:45 amIf the freebies don’t help and you’ve no money, then AE’s own vector paint can work almost as well.
Create a new black solid over the layer, set the transfer mode to color burn, goto the frame where you want the flash and paint a jagged flash shape in a light yellow colour. Use a feathered brush ideally. you should get a white blob tinged with yellow. Advance one frame and draw a smaller blob. And that’s it!
I’ve used this for ages and am very happy with the result.
Graham
Mcvideo
August 5, 2005 at 1:59 pmMinimum
Surly
Another application you get purchase for a reasonable price can be found at fxhome.com. Check out the demo version to Effects Lab, and Chromanator (great for green/blue screening)
Effects Lab has great features for muzzle flashes etc. Check out the videos under Cinema/movie archive. All effects on all video are 90% done with the Effect Labs application. I know there are others out there but this application is great and offers wonders for a great price too!!
Here is a link to a movie in my favorites. Look out for the muzzle flashes. Video courtesy of Cobra Productions:
https://cobraproductions.filmspace.biz/dtf.mov
Check out the movie archives for different movies. Some are really impressive.
