Activity Forums Adobe After Effects Expressions Looking for an expression that will handle 24 dots rotating in circle, then line up in 2 lines of 12.
  • Looking for an expression that will handle 24 dots rotating in circle, then line up in 2 lines of 12.
    Posted by Brian Struble on November 3, 2014 at 2:52 pm
    Hi:
    I need some help in developing an expression that will rotate 24 dots (or balls) in a circle for 2 rotations, then settle into 2 lines of 12 dots, one line above the other. Does anyone have any suggestions that might get me started?
    Brian Struble
    Jason Jantzen replied 11 years, 10 months ago 2 Members · 1 Reply
  • Jason Jantzen
    November 10, 2014 at 3:59 pm
    I just saw this, but if you’re still stuck, I use a script for this called Gridder https://aescripts.com/gridder/ It has an option to generate an expression controller to animate the circular grid into a rectangular grid. I believe so, anyway. If not, you could always use the script to arrange your circle, make your key frames, then use the script again to arrange them in a grid.
    Jason Jantzen
    vimeo.com/jasonj
