Activity › Forums › Adobe After Effects › Looking for a way to approach a transition/fade substitute
  • Looking for a way to approach a transition/fade substitute
    Posted by Ryan Shea on January 11, 2014 at 6:38 am
    Hi All:
    I’m currently working on a video infographic of sorts, which includes a globe. In the previous draft of the animation, I had a simple CC sphere applied to the image, which gave me what I wanted. I then used a simple opacity fade to change the color of the globe.
    I’m wondering what I could use to make the transition between colors more dramatic – when I used a fade, the color change is almost unnoticable. I imagine that there could be a more interesting way to present that the globe is changing.
    This is my current animation that I have (the globe changes from a blue to a red-ish): https://i.imgur.com/yOdortD.gif
    Thanks in advance!
    View post on imgur.com
    John Cuevas replied 12 years, 8 months ago 2 Members · 1 Reply
  • John Cuevas
    January 11, 2014 at 2:09 pm
    Well if you precomp your map-you could do some transitions in the precomp-then apply CC sphere to that precomp. A wipe might be a little bit more dramatic, or maybe even a CC Light Wipe.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
