Activity › Forums › Apple Final Cut Pro Legacy › Looking for a sound effect and going nuts not finding anything for it, haha
  • Looking for a sound effect and going nuts not finding anything for it, haha
    Posted by Evan Seitz on May 11, 2012 at 3:16 am
    Does anyone know where I can find a sound effect for the fast scrolling of numbers up or down? I tried even looking up something like an airport departure board, but got nothing. I swear it’s used all the time in commercials, but I have no clue what to search for and have tried everything I could think of. Any help would be greatly appreciated!
    John Pale replied 14 years, 4 months ago 3 Members · 3 Replies
  • Scott Sheriff
    May 11, 2012 at 3:51 am
    I know what your talking about. I’m bet someone has footage of the mechanical departure/arrival boards. Here are some sound alike suggestions that might work in a pinch:
    Card shuffle, slowed and heavily EQ’d.
    Look for old sound FX, or stock footage of a punch card reader or sorter. Sometimes older SFX labeled ‘computer’ will have this sound.
    Old mechanical adding machines like accountants would use, might work if you edited the sound in a loop.
    Close mic a rotary phone being dialed. With some pitch change and EQ, the dial return sound might work.
    Footage of a teletype machine might also work. Most teletype messages have an underline, or a series of X’s separating the messages. Those repetitive characters might work. There are also some repetitive electric typewriter sounds in the STP SFX library.
    Look for footage or SFX labeled toteboard, or toteboard change.
    If you find something close, don’t forget there are lots of tricks you can use, pitch change, reverse, EQ, layering.
    If you can’t find anything, let me know. I have a teletype that might work in my stash.
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    “If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
    Where were you on 6/21?
  • Evan Seitz
    May 11, 2012 at 4:23 am
    Searching “Teletype” was perfect – thanks so much!!
  • John Pale
    May 12, 2012 at 4:56 pm
    I actually use a rattlesnake sound for something similar once. Worked very well.
