Activity › Forums › Adobe After Effects › Looking for a position expression
  • Looking for a position expression
    Posted by Adam Lewen on July 27, 2017 at 8:23 am
    Hi there!
    I would like to have a null moving/sliding a 2 layer GFX on the x <–> but each of the layers need to “seem” as if in a bit of a different depth.
    here is a great example of the look:
    https://space.vanderlanth.io/ – The 2 layers here are images/ text
    the side sliding…
    I would love to avoid 3d layers and cameras!
    Thanks for any tip!
    Adam
    Adam Lewen replied 9 years, 2 months ago 2 Members · 2 Replies
  • Andrei Popa
    July 27, 2017 at 8:32 am
    To get started you can do this. Create a null. right click position->Separate dimensions. Animate the x. Then on the layers you separate dimensions also. Alt-click x position of the layer and pickwhip to the x of the null. Same for the second layer, but you just add something like *1.5 at the end of the expression. This layer will move 1.5 times more/faster.
    Andrei
  • Adam Lewen
    July 27, 2017 at 9:02 am
    Thanks Andrei. Sounds simple and makes sense.
    I thought there might be a ways with 1 null but its probably simpler with 2.
