Activity Forums DaVinci Resolve Looking for a confirmation of an unexpected Input/Sizing behavior.
  • Looking for a confirmation of an unexpected Input/Sizing behavior.
    Posted by Dmitry Kitsov on March 17, 2012 at 11:55 pm
    In 8.2 if any type of zoom/pan/tilt applied to a clip, when “Basemem” any of the nods all of the sizing resets as well? Didn’t it used to be independent of the nodes? If it is now a nod dependent operation why does a reset happens regardless of which node the “Basemem” happens to?
    Could someone confirm?
    Dmitry Kitsov replied 14 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Gabriele Turchi
    March 18, 2012 at 2:45 am
    Same behavior on my system ..
    I actually emailed support about it couple of days ago …
    No answer yet …
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rockets
    GTX470+GTX470+GTX285
    24GB RAM
    HP Dreamcolor
    Panasonic 58PF Plasma
  • Dmitry Kitsov
    March 18, 2012 at 4:58 am
    Thank you. I think it is a new behavior.
  • Gabriele Turchi
    March 18, 2012 at 5:02 am
    feel if it is designed this way … i really don’t like it …i use the base mem button in the davinci panel a lot … and so i lose the PTZR …
    hope they change it/fix it
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Rohit Gupta
    March 18, 2012 at 11:14 am
    There is a function in the Session menu – “All/Color/PTZR”. There is also a button on the control surface called Current Mode I believe.
    This control the behavior of a few things:
    1. Basemem – will reset all, current node, or sizing
    2. Add Mark/Dynamics – will add to all, current node or PTZR/Sizing
    3. Copying grade from stills and memories – will copy both, color or sizing only
    Hope this helps!
  • Gabriele Turchi
    March 18, 2012 at 2:31 pm
    mmm… i always use that button , and i usually stay parked in “color” so when i add dynamics it effect only that node ,
    so basically when she use a zoom tool we should stay parked in PTZR in order to apply the zoom only to that node ?
    i will try on monday …
    thanks a lot
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Gabriele Turchi
    March 19, 2012 at 12:05 am
    ok just tried ,
    it works as rohit described , to reset anything but PTZR the ALL/COLOR/PTZR have to be parked on color
    thanks
    g
    MacPro
    Cubix desktop 4
    2 Red Rockets
    24GB RAM
    HP Dreamcolor
  • Dmitry Kitsov
    March 19, 2012 at 12:48 am
    Thank you very much. Can’t believe I could overlook something so obvious.
