Activity Forums Adobe After Effects Expressions Look at Camera expression similar to C4D
  • Look at Camera expression similar to C4D
    Posted by André Vandenburg on February 19, 2026 at 4:43 pm
    I have this “galaxy” setup in After effects. Each sphere is a precomp where I control the texture and lighting source. Each ring of spheres is parented to a null and they are all 3D shape layers. The camera is parented to a null at the center of the galaxy. Each instance of the sphere is a single precomp. When I use auto-orient to the camera, it throws off the directionality of each precomp by causing the rotation to vary. Is there an expression I can use to lock down these spheres so they stay perpendicular while facing camera?
    André Vandenburg replied 6 months, 2 weeks ago 1 Member · 0 Replies
  • 0 Replies
