Activity › Forums › Adobe After Effects › Long saving and purge times
  • Long saving and purge times
    Posted by Jake Hardiman on October 8, 2020 at 3:47 pm
    My After effects projects are slow to save sometimes taking as long as 20 minutes on an SSD. I am getting a very similar issue when purging my cache.
    The issue is super strange as if I open a window in front of AE the saving bar or purge bar shoots up. So when I save I have to open a window in front of the AE so decrease the save time from 20 mins to 1 min.
    Hopefully, someone has come across a similar problem before.
    Many thanks
    Michael Szalapski replied 5 years, 11 months ago 3 Members · 5 Replies
  • Michael Szalapski
    October 8, 2020 at 4:32 pm
    That’s super-weird. What version of AE and what OS?
  • Blaise Douros
    October 8, 2020 at 9:00 pm
    I’ve seen something similar–for awhile, if I was rendering a Dynamic Linked AE project in Premiere, it would hang basically forever…unless I clicked into AE, and then back into Premiere, at which point it would render like normal. It was 100% consistent.
    What I did to fix this was…nothing. I just dealt with it for awhile, and then it stopped happening. I have no explanation for why it did this, because I didn’t update versions–maybe some minor OS updates, but I’ve been on the same OS version and release of PP and AE for a long time.
    Supremely helpful, I know, but your problem sounds similar enough that it seemed mildly relevant.
  • Jake Hardiman
    October 9, 2020 at 11:08 am
    Here are some more details:
    Its a Windows machine.
    I am currently on AE 17.1.4. but I have also had the same issue on 17.0.1
    I am using a SSD is samsung evo internal drive
    The problem happens regardless of what hard drive is being used.
    I have collected all the my project footage into one place on the same hard drive and the problem still persists.
    The project I am testing is 19.9 MB. however it’s happening on all my projects
    I Did the following test below.
    If I click save without touching anything its taking 7 minutes to save
    If I hit save and open a window in front of AE it only takes 3 seconds to save
    Do you know why is this the case? Thanks
  • Michael Szalapski
    October 9, 2020 at 6:01 pm
    I’ve never heard of that sort of thing happening. Hopefully someone else has, but at least you have a way to speed things up in the meantime!
  • Michael Szalapski
    October 10, 2020 at 4:34 pm
    What plugins do you have installed, by the way?
    I was talking with someone else about your issue and they know older versions of Stardust and Supercomp have both caused similar issues.
