Activity Forums Apple Final Cut Pro Legacy Long Form Capture
  • Long Form Capture
    Posted by Steven J. gilbert on February 14, 2008 at 12:26 am
    I have a tape for a client that is shot with about 300 separate shots. When I captured the footage the first time the deck search for the head of the clip and captured separate clips. The problem is clips were captured late by about 30 – 45 frames. I have to recapture the footage and want to capture as one clip. I was having problems finding the settings to adjust in FCP4.5 HD to capture the clip as one.
    Steve
    Shane Ross replied 18 years, 7 months ago 3 Members · 5 Replies
  • Steven J. gilbert
    February 14, 2008 at 1:08 am
    The clips I am capturing has breaks in the timecode and th ecapture is stopping on the breaks. i just want to capture as one large clip.
    Steve
  • Shane Ross
    February 14, 2008 at 3:46 am
    Set deck control to UNCONTROLLED DEVICE. This will make FCP ignore the timecode and capture over those breaks.
    Bear in mind that without timecode reference, if you lose your media, erased, drive failure, then your edit is gone. You’ll have to recapture and re-edit. With time code, you can recapture tapes exactly the way you did the first time and your edit will be preserved.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Shirlyn Wong
    February 14, 2008 at 3:53 pm
    You could also dub the tape over with fresh new TC there avoiding any kind of TC problems if you need to go back to the source.
    I could be wrong but last time I remember the function Capture Now, allows you to take in video across TC breaks where FCP makes new clips during every break. Although rumor has it (but I found not be true in my cases) that TC is not recorded during Capture Now.
  • Steven J. gilbert
    February 14, 2008 at 4:48 pm
    Shane,
    I trashed preferences before this project and reformatted the media drive. I captured the tape just fine now. It shows up as a 30+Gb clip on the drive and play in QT just fine. The problem is if I impoort the clip into FCP it shows only as the first clip of a little over a minute. Thanks.
    Steve
  • Shane Ross
    February 14, 2008 at 4:57 pm
    That is truly odd. Never seen that before.
    Sorry.
    Shane
    http://www.LFHD.net
    Read my blog!
