Activity › Forums › Adobe Premiere Pro › Long encode for web
  • Long encode for web
    Posted by Calvin Dean on February 8, 2006 at 1:12 am
    I have to shoot and encode a presentation that will run 1 to 1.5 hours. What is the best way to handle the encoding so it will start streaming almost immediately when clicked? Should it be WMV? MPG1? Other?
    I can encode using PPro 1.5 or Sorenson Squeeze 3.0.
    I’ve never encoded a file this long…I’m concerned about performance.
    Aanarav Sareen replied 20 years, 7 months ago 2 Members · 3 Replies
  • Aanarav Sareen
    February 8, 2006 at 1:39 am
    If you want to Stream immediately, your best bet would be Flash Video. I am not an expert on Flash Video or Flash in general, but stop by the COWs Flash forum and you may get a better detailed response.
  • Calvin Dean
    February 8, 2006 at 1:45 am
    Thanks, Annarav. Before I head over to the Flash forum, can I convert to Flash using PPro or After Effects. I don’t have Adobe/Macromedia Flash software. And what about a file that large?
    And let’s just say this file has to be WMV or MPG1. Is there a way to have it stream soon after clicking on the hyperlink? What other issues might I encounter?
  • Aanarav Sareen
    February 8, 2006 at 3:13 am
    Well, with the other formats, you may notice repetitve buffers, which is something you want to avoid because it is really annoying to view a video that stops and resumes every couple of seconds. But, that all depends on the web host you are using.
    You can export flash video from AE 7 and Premiere Pro 2.0
