Activity › Forums › Adobe After Effects › Logo that wraps around a person..using AE CS3?
Posted by Gary Degennaro on July 8, 2008 at 12:23 amHi,
I want to make the company logo fly/wrap around a person.
For example, the commercial is for back pain. There is video of a person with red throbbing aching back pain. Then the back pain product logo flies in and wraps around the persons midsection around the back (like superman flying around the earth) and flies away. The pain is gone.
Could someone please give me the best way to approach something like this?
I am using After Effects CS3.
GaryDave Montague replied 17 years, 8 months ago 9 Members · 11 Replies -
Ron Lindeboom
July 8, 2008 at 3:07 amThis kind of thing is done using 3D applications, not After Effects. You may be able to use mesh warps and a few other tricks — to a point — but I sure wouldn’t want to try and tackle the problem that way.
Best regards,
Ron Lindeboom
Remember: Burt Bacharach lied. What the world really needs now is an undo button.
Scott Novasic
July 8, 2008 at 3:14 amI agree with Ron, your best shot in ae is with a mesh, or I would use a bezier warp and have both layers in 3d space. You may or may not have to use some layering tricks and or a mask to make it work.
3d is best if you have the skills.
SuperNova
Animation & Visual Effects
Scott Novasic
Los Angeles Ca
web:https://web.mac.com/finaleffects -
Tom Scott
July 8, 2008 at 5:44 amAlthough best results would come out of a 3D program, it can be done in AE.
See if you can modify this tutorial for your needs. -
Gary Degennaro
July 8, 2008 at 10:19 pmThanks for the feedback everyone…
Tom, Im going to give that tutorial a shot and Ill let everyone know how it turns out.
Gary
Peter Mcauley
July 9, 2008 at 5:37 pmHi Gary,
If you use Boris RED 4 as a plug-in inside of AE CS3 then you can place the person on a plane, place the logo on a cylinder and place the plane and the cylinder into a 3D container. Then you can rotate the cylinder and the logo will wrap around the person just as you wanted it to.
You can download the Boris RED 4 trial version and use it for free without watermark for two weeks. And you can download it here: http://www.borisfx.com/downloads
I hope this helps.
Peter.
Chris Wright
July 9, 2008 at 8:58 pmanother method is use monet to roto mask the actor from the background, then you are free to do w/e you want with effects like cylinder effect, then when you add person again, they will automatically overlay the effect perfectly.
Ron Lindeboom
July 9, 2008 at 9:05 pmThat’s what I get for reading these posts so fast! ;o)
I thought the effect was not just a simple clean cylinder wrap but a more uneven map/appliqué to the guy’s body/midriff — hence the 3D app or mesh warp suggestion.
One of these days I’ll actually slow down.
:o)
Thanks for popping in, Peter. Nice to see you found this forum.
Best regards,
Ron Lindeboom
Peter Mcauley
July 9, 2008 at 9:36 pmHeheh … that exact same thing happens to me too. 🙂
Yeah, I discovered this forum just by accident through the larger items of interest that you have as a sidebar on the main forums page.
Glad I could be of help.
Cheers,
Peter.
Ken Latman
July 11, 2008 at 8:46 pmYou might be able to get the effect using some techniques found in Photoshop for wraping objects with sort of a displacement map. If you can isolate the object you probably use the same trick you would in Photoshop and have your text run over the displacement map.
Scott Roberts
July 18, 2008 at 5:03 amI recall seeing a tutorial a few years back that used expressions to do this type of effect. I think it demonstrated swirling a string of text around an object. Sorry, can’t recall where I saw it, but I believe expressions were used extensively. Maybe Computer Arts magazine? hmmmm
Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
https://www.littleblackbird.com
