Activity Forums Apple Final Cut Pro Legacy Logo looks jaggy (& blurred) on dvd
  • Logo looks jaggy (& blurred) on dvd
    Posted by Tommaso Cicognani on June 10, 2009 at 8:53 am
    hi all,
    I’m finishing a work (corporate work) for a client who want the distribute the product on DVD. He sayes that most of the viewers will see it on computer (and not TV!).
    Now I have problems becouse logos don’t look good and the client is really disappointed.I told him that is not possible to look good a dvd (sd 720×576)on a computer monitor (at least 1024×768)..
    here my workflow:
    Shotted and edited in dvcam
    lot of 3D stuff inside the project
    + logos and lower thirds
    exported all in proresHQ (YUV)
    than use compressor to do the dvd encoding
    Logos (especially the small one at the bottom of the screen (see pics)) keep on seem blurry and a bit jaggy. I did all the scaling in Photoshop not in FCP.
    Is it correct what I’m doing?
    Please help!
    tommaso
    Tommaso Cicognani replied 17 years, 3 months ago 2 Members · 3 Replies
  • Tommaso Cicognani
    June 10, 2009 at 9:25 am
    ..forgot the pics…
  • David Roth weiss
    June 10, 2009 at 3:34 pm
    [tommaso cico] “Shotted and edited in dvcam
    than use compressor to do the dvd encoding “
    Tommasco,
    You can’t simply export as Pro Res to get the benefits of the codec. You need to change the compressor in Sequence>>Settings to Pro Res, then re-render the entire sequence, then export a self contained QT at current settings using Export>>Quicktime Movie.
    Hope this helps.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Tommaso Cicognani
    June 10, 2009 at 3:58 pm
    thank-s david for the help,I discovered:
    1. If my seq. setting is in dv and I export a reference movie looks bad.
    2. If my seq. setting is in dv and I export, with quicktime conversion, in prores is good (better than dv!)
    3. If my seq. sett. is in prores and I export a ref. movie the results are quite the same as the second point: I notice some changes in how it renders colors.
    Definitively, which is the correct one? My problem still persist.
    One more question: If I want to export it for the web is it correct to do as follow:
    1. export the project in prores hq in a RGB sequence
    2. use compressor to convert it to h264 full quality with deinterlace filter set to SHARP (I triend use ODD option in the deinterlace option tab but it destroy my little logo).
    Any advice?
    thanks
