Activity › Forums › Maxon Cinema 4D › Logo extrude and illustrator import weirdness
  • Logo extrude and illustrator import weirdness
    Posted by Elin Grome on September 10, 2008 at 8:56 am
    Hi guys,
    Noob – Looking for some help in creating a logo extrude; For one of those FOX sports style chrome team badges.
    2 things:
    a) If anyone has any tutorials/pointers would be great, obviously some extruding bending gonna be needed – im sure i can figure it out but always easier to stand on the shoulders of others 😉
    b) specifically related to import of ai artwork. Ive imported the artwork using the merge command and unchecked the “connect splines” pref etc. All fine, I then set about moving the splines into the appropriate groups and naimg them.
    Now thats where the problems come… splines just start dissappearing… then appearing again… or not… or sometimes i make all splines invisible in the object manager but some remain visible :s so i open the artwork in another c4d project then re-copy over the missing splines… etc etc… no particular method, just madness…
    Anyone had these experiences? Is it re-draw, bug or my rampant crack habit 😉
    Cheers for any advice,
    Elin
    Randy Johnson replied 18 years ago 2 Members · 4 Replies
  • Elin Grome
    September 10, 2008 at 9:01 am
    …hidden splines remain visible :s
  • Elin Grome
    September 10, 2008 at 10:06 am
    …that its best to import those problematic splines separately – using connect splines where necessary…
    v much like the little ive seen from c4d – but this seems to be one thing that could be improved 🙁
  • Elin Grome
    September 14, 2008 at 1:57 pm
    Hi all,
    so ive finally managed to extrude my illustrator splines and create a simple extruded logo with some materials, now i need help sprucing it up a bit as its rather “flat”; just a simple extrude with caps to soften the edges…
    I would really like to put some more detail onto the whole object, how to i create much softer, rounded surfaces rather than flat extruded caps? of course i can push/pull points but im sure there must be an easier way?
    Ive messed about with bulge, bend etc but no real joy 🙁
  • Randy Johnson
    September 18, 2008 at 6:12 am
    its really hard to make a suggestion not knowing what the object looks like.
    /randy
