Activity Forums Apple Motion logo emitter
  • logo emitter
    Posted by Vaportrails on July 1, 2005 at 2:33 pm
    How can I change the word “pillusion” to say something else? I like the effects used with the logo emitter file, I just want to use other words
    Jayson Steckler replied 21 years, 2 months ago 3 Members · 3 Replies
  • Scot Walker
    July 1, 2005 at 4:54 pm
    Can you elaborate a bit more on what you are doing?
    If you want to make a particle emitter out of a logo, select the logo and then click on the “Make Particles” button in the toolbar.
    Is that what you want to do?
  • Vaportrails
    July 1, 2005 at 7:41 pm
    Thanks for quick response!
    I would like to use the effects that are used with the logo effects group. It’s has things like spin, spin grow, converges and shrinking etc. I don’t know how to change the word ILLUSION that shows the effects happening in the preview box.
    I would like to type a different word and have PI apply it’s effects that are in the logo effects.
    Any help would be appreciated?
  • Jayson Steckler
    July 1, 2005 at 9:16 pm
    I’ve not seen this emitter in person, but if it’s using a footage object (still or movie) as it’s source, you can replace it with another object by dragging the new object onto the source. If it’s actually using a text object as it’s source, simply select the text object and type your own text.
    (The source refers to the object that was turned into a particle (Note it doesn’t reside in the Emitter) and is grayed out. ie: Blur08 is the source in the Basic Smoke particle emitter.)
