Activity Forums Apple Final Cut Pro Legacy Logging and Transferring in Final Cut 5?
  • Steve Eisen
    June 7, 2009 at 1:33 am
    Log and Transfer was introduced with FCP 6.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Shane Ross
    June 7, 2009 at 1:58 am
    As said, LOG AND TRANSFER was introduced in FCP 6. Before, in FCP 5, it was only used for P2 footage. In FCP 6 it was expanded to support more options. If you shot with AVCHD, or other tapeless format, you will need FCP 6 in order to import it.
    Or…if it is AVCHD, you can use Toast 10 to convert it to a format FCP can edit.
    Shane
