Activity Forums Avid Media Composer logging 8-perf (vistavision) clips
  • logging 8-perf (vistavision) clips
    Posted by Miles Archer on August 25, 2005 at 11:26 pm
    using xproHD5.1.6, I’m capturing video xfer from betasp, through mojo, of some VistaVision vfx plates.
    Once I log the clips, I try to type the KN start, but when I do, the “feet” number is double what I typed. (or the last four digits of double what I typed).
    Am I doing something wrong?
    I’m also having trouble getting the key numbers to “stick”. I type them in, hit enter, and nothing’s there. I tried exporting an .ale, editing it, and reimporting, but don’t get any options to choose the film format that way — frames count up to 15 before rolling over the footage count.
    any thoughts?
    Miles Archer replied 21 years ago 2 Members · 2 Replies
  • Michael Phillips
    August 26, 2005 at 6:43 am
    VistaVision is tracked in the Ink Number column. Go to the Film Settings first and set the Ink Number settings to Keykode and the “count” as vistavision. The ink numbers values entered after setting it as such will count as 8 frames per count.
    Michael
  • Miles Archer
    September 7, 2005 at 5:02 pm
    I’ve been awfully busy the last couple weeks and neglected to thank you for the response.
