Activity Forums Apple Final Cut Pro Legacy Logging 2 tapes same timecode FCP
  • Logging 2 tapes same timecode FCP
    Posted by Edworld on September 25, 2006 at 9:14 pm
    I had to translate this so I am also sending the spanish version as clarification in case I am not clear and someone there speakes spanish.
    We have to capture material from 2 different tapes with the same time code. We do one batch list, duplicate it as new master clip and change the reel number from the browser in order to capture the second tape. The first capture is without problems, but the second one wants to use the same names as the first. So far, we go in and change the names in the finder, and then reconect. Is there another option?
    Bueno, el problema es el siguiente: Tengo que capturar material de dos tapes que tienen el mismo time code. Hago un solo Batch list, lo duplico como nuevo master clip (duplicte as new master clip) y cambio el numero de reel desde el Browser para poder capturar el segundo tape. Capturo el primer tape sin problemas, pero al capturar el segundo me nombra los master clips igual que los primeros, y la unica opcion que me queda es cambiar sus nombres en el finder (y de esta manera despues tengo que reconectar desde el FC cada clip nuevamete). Cual es el problema? Debo loguear 2 veces, una por cada tape?
    Lon Keller replied 19 years, 11 months ago 6 Members · 6 Replies
  • Mark Maness
    September 25, 2006 at 9:18 pm
    Did you change the reel names in your Browser window? That is where the files get their name from. You can’t just change the files, you need to change the names on the clips in the Browser window, too.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Jeremy Garchow
    September 25, 2006 at 11:35 pm
    i do this while logging. After you log the first clip, drag it back into the log and capture window (all of the clips attributes are now preserved) then I change the clips reel name and camera angle (if you are using the multiclip feature). Sorry I don’t speak Spanish, otherwise I’d translate for you.
    Jeremy
  • John Barnard
    September 25, 2006 at 11:39 pm
    You could just start a second Final cut pro project and do your capturing from the second tape in there.
    Then, when you’ve got everything captured, open both projects at the same time and drag the clips from one into the other.
    That’s how I’d do it… mind you, I’m not a particularly efficient person.
    OS 10.4.7
    G5 1.8 single
    Huge Mediavault
    Atto ul4d2
    final cut 5
    Sony DSR-45
    QT 7
    Decklink drivers 5
  • Lon Keller
    September 26, 2006 at 2:18 pm
    This is what works for me…
    1. Log and load footage from tape 1
    2. Select all clips in the bin and duplicate as new master clip
    3. Drag those clips into a new bin
    4. Take those clips in the new bin and make them offline, but LEAVE THE MEDIA ON THE DRIVES
    5. Change the reel number of the new clips to Tape 2
    6. Capture your footage from Tape 2
    Hope this helps…
    Lon
  • Greg Ball
    September 26, 2006 at 4:37 pm
    This all seems very complicated . I haven’t done this yet, but often shoot multi-cam projects with two or three cameras having the same timecodes. Can you just change the reel names and put each reel in it’s own bin?
  • Lon Keller
    September 26, 2006 at 6:13 pm
    Essentially, that’s what I’m doing with the steps I’ve outlined above.
    Lon
