Activity Forums Apple Final Cut Pro Legacy Log & Transfer Jumpy Frames
  • Log & Transfer Jumpy Frames
    Posted by George Robbins on April 17, 2009 at 2:39 pm
    Trying to digitize AVCHD footage from chip, plays fine in Log & Transfer video, but when I import in project every 15 frames jumps for 1 frame 15 frames back, then proceeds along fine until the next jump. I’ve digitized same footage on other machine so it’s not the source footage that is problem, and when I use any other footage in the same project (including same source just digitized on a different machine) it plays back just fine.
    any ideas?
    thanks!
    Colin Jackson replied 17 years, 5 months ago 2 Members · 1 Reply
  • Colin Jackson
    April 29, 2009 at 4:28 pm
    I ran into this last week, too. I did some searching around and figured out that having Perian installed was what was causing the issue. If you have it installed, go into System Prefs > Perian and click “Uninstall Perian.” Then restart your system and everything should be working after that.
