Activity Forums Apple Final Cut Pro Legacy Log & Transfer footage from P2
  • Log & Transfer footage from P2
    Posted by Daniel Pinne on December 18, 2011 at 4:49 am
    Hi Everyone,
    So I’m really new to this game and would appreciate anyone’s help in as simple terms as possible. I’ve read a few other forums but have got quite confused and some of the threads seem to go on tangents just when I think I’m about to get the answer.
    Anyway, I’m currently using FC Pro 6.0.6 and I’ve previously successfull log & captured footage from a P2 card using the instructions that from a previous post on here.
    I’ve gone to log & capture some other footage using the same steps, but the folders appear empty with no clips in them. I’m positive there is footage in there, but the Log & Capture window will not read the clips correctly. I haven’t changed any significant settings from the previous import so I’m confused as to why it won’t read it correctly. Can someone please help? I’ve attached a screen shot below that shows the folder ‘151211’ with no clips in it. It should have at least 2 decent size clips in it.
    Any help would be appreciate, thanks in advance.
    Shane Ross replied 14 years, 8 months ago 3 Members · 4 Replies
  • Shane Ross
    December 18, 2011 at 10:42 am
    Are you sure? Look in the VIDEO folder in the CONTENTS. Are there files in there? If so, is the full card structure intact? Anything in the OTHER folders? Without a fully intact card structure, FCP cannot see a thing.
    Shane
    Little Frog Post
  • John Heagy
    December 18, 2011 at 7:27 pm
    Is this DVCProHD or AVC-I P2? If AVC-I you will need to install the Panasonic AVC-I codec. FCP 6 doesn’t support AVC-I out of the box.
    John
  • Daniel Pinne
    December 18, 2011 at 10:10 pm
    Hi Shane,
    The Audio, Clip, Icon & Video files all have files in them. The Icon folder shows me that it’s definitely the footage that I’m after.
    Any other thoughts?
  • Shane Ross
    December 19, 2011 at 7:30 am
    Well, is the footage AVCIntra like John mentioned?
    Shane
    Little Frog Post
