Activity Forums Apple Final Cut Pro Legacy log notes do not appear from capture
  • log notes do not appear from capture
    Posted by Genevieve H. ritter on February 11, 2007 at 8:42 pm
    I have been using Capture Now. I put in a log note and also might check the box that says “good” for the type of take. When I look at the clip in the browser, the clip is there, but nothing is noted in the log note column, nor in the column that notes “good” for the take if I had that checked before I begin Capture Now. How can I make my log notes appear, or must I do a batch capture to make the log notes appear?
    Jerry Alto replied 19 years, 6 months ago 2 Members · 1 Reply
  • Jerry Alto
    February 12, 2007 at 1:43 am
    GenDelmarva- Use the ‘capture clip’ button. It will give you the log notes. ‘Log clip’ and ‘batch capture’ also will give you logging entries.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
