Activity › Forums › Apple Final Cut Pro Legacy › Log & Capture Mystery!
Posted by Gautam Pandey on February 11, 2011 at 6:07 amHi all,
Have a strange issue at hand…
Footage looks fine in the Log & Capture window, but when I do Captuer now the footage is B&W!
On the timeline however its colour.
Another issue was while capturing the audio would stop and there would be VERY loud static noise almost like a bad cable connection.
However if i stop the capture and refresh FCP the audio is back.
ANy ideas why this might be happening?
Gautam Pandey
http://www.riverbankstudios.comGautam Pandey replied 15 years, 6 months ago 5 Members · 17 Replies -
Shane Ross
February 11, 2011 at 6:19 amWhat type of deck? How is it connected? What type of footage? Is there a capture card involved?
You’re leaving us pretty blind…
Shane
Read my blog, Little Frog in High Def -
Gautam Pandey
February 11, 2011 at 6:27 amSorry about that…
FCP version 6.0.6
Deck – Betacam connected through YRB
Footage is SD PAL
Capture Card – AJA Io
Not really an editor myself, so apologising in advance if i seem a little ‘thick’ about things 🙂
Gautam Pandey
http://www.riverbankstudios.com -
Shane Ross
February 11, 2011 at 6:36 amPose that in the AJA IO forum…might get more help…
https://forums.creativecow.net/ajaio
Shane
Gautam Pandey
February 11, 2011 at 6:49 am -
Paul Jay
February 11, 2011 at 9:56 amIn your AJA control panel set analog input to COMPONENT.
Now it’s set to Y/C or Composite. That will give you black and white signal.
No mysteries here.
Gautam Pandey
February 11, 2011 at 11:13 am -
Gautam Pandey
February 12, 2011 at 4:51 amHi Paul,
I can’t seem to locate the aja control panel! I suspect this might be part of the problem. Though all the setups are available in FCP.
The only AJA folder I found was in a FCS2 Update folder.
Would you recommend i try reinstalling the AJA software?
Gautam Pandey
Paul Jay
February 14, 2011 at 9:23 amIt’s in your Applications folder.
If not, you haven’t installed any AJA drivers
Gautam Pandey
February 14, 2011 at 1:03 pmYup.. not there..
I’ll install the drivers and post the results.
Thanks 🙂
Gautam Pandey
