Activity › Forums › Apple Final Cut Pro Legacy › Log & Capture Issues
Posted by Darrin on November 2, 2005 at 3:47 amHas anyone else had issues with not being able to log & capture clips after updating the latest FCP software…?
Cheers,
DarrinLansford B replied 20 years, 10 months ago 5 Members · 5 Replies -
Jeremy Garchow
November 2, 2005 at 4:03 amPlease give more info. DO you have capture hardware? Are you using DV/firewire? Are you talking about the upgrade from 5.02 to 5.03 or are you talking a full upgrade from panther to tiger and qt 6 to 7?
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Joseph Bradley
November 2, 2005 at 5:30 amI’ve heard of some serious drop frame issues but nothing on why or how to fix it. Anyone? Anyone?
Bouncing Account needs new email address
November 2, 2005 at 1:39 pmYou need to always be very specific when asking a question.
Try looking here:
https://docs.info.apple.com/article.html?artnum=301852
Darrin
November 2, 2005 at 6:12 pm…sorry guys….running FCP 5 and Tiger on a dual 2.0 G5….never had this issue until after I did the last software update from Apple…..I open FCP and open the log and capture window, and it says that there’s no communication from the VTR…..I’ve been through every setting possible and still no communication…..
Lansford B
November 3, 2005 at 4:35 pmI am having major issues with capturing. FCP 5 tells me there are timecode breaks where none exist. I am new to FCP and am starting out with v.5. I am trying to capture a segment that is a continuos shot without starts or stops. Dan and David were talking about this in a july thread and suggested several things to check. The problem was not isolated to any certain equipment except for FCP. The solution at that time was to change the User preferences to “Warn after capture”. has any other solution been found?
I tried for 2 days to capture a clip and could not get past the first 10 seconds. This does the same thing when trying to capture a clip and when trying to use Batch Capture. I played with all the settings and tried to trouble shoot. When i found Dan & David’s thread I had done everything they suggested I check. I am using a Sony DSR-80 DVCam deck thru a Matrix switcher to an AJA IO LA box and into the Mac G5 with firewire. I have a Dual G5 with an outboard G-Raid 500 Gig drive. I am not running Tiger because of Media100. I finally quit the FCP project and went back to the Media100 and the segment captures flawlessly. Am i doing something wrong? Can you help me, I would appreciate your wisdom. Thanks
