Activity › Forums › Apple Final Cut Pro Legacy › Log and transfer question
  • Log and transfer question
    Posted by Marcus Carlton on May 8, 2009 at 2:07 pm
    I’m attempting to use the log and transfer function with clips from a Focus ProHD DR-HD100. Every time I attempt to log and transfer the clips, it tells me the folder where my clips are “contains unsupported media or has an invalid directory structure.” These files are quicktime dv files. What am I doing wrong here?
    Info on the files:
    720×480
    Codecs:dv/dvcpro-ntsc
    integer (big endian)
    John Fishback replied 17 years, 4 months ago 3 Members · 2 Replies
  • Thomas Clayton
    May 9, 2009 at 12:08 pm
    Try log and capture. Log and Transfer is for Panasonic HD files, thus your DV files are unsupported.
    Thomas Clayton
    MFA Student UNC Greensboro
  • John Fishback
    May 9, 2009 at 4:17 pm
    If the source is QT files just try to Import the files. You don’t need to transfer or capture. You may need to copy the files to your external capture scratch drive before importing them.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
