Activity Forums Apple Final Cut Pro Legacy log and transfer of P2 data has no audio
  • log and transfer of P2 data has no audio
    Posted by Jim Kinsey on December 10, 2008 at 2:36 pm
    I believe this has been going on for a while when you open the log and transfer window and your clips populate window but when you try and begin the process of importing them none of the clips have audio. Is this a QT problem? I hear of the fix of closing FCP then reopening the application. It has been hit and miss with this one and now I am not getting any audio for reference at all? Any ideas. Thanks in advance.
    Jim Kinsey replied 17 years, 9 months ago 2 Members · 2 Replies
  • Shane Ross
    December 10, 2008 at 4:20 pm
    What version of FCP? What version of Quicktime?
    IN the LOG AND TRANSFER window, lower right box…IMPORT SETTINGS. Click on that and make sure that things are set so you are importing audio as well.
    Shane
  • Jim Kinsey
    December 11, 2008 at 3:14 am
    Shane,
    Thanks. Version 6.0.5 and the latest QT version. I show audio bars in the pane but have no audio output while trying to log the P2 data. Once I que a few clips and import into the browser( FCP) as QT files they work. The only time I can’t hear the audio is while previewing in the log and transfer window.THis has been going on for a while… is there a fix from apple yet or still a bug they haven’t figured out?
