Activity › Forums › DSLR Video › log and transfer issues in FCP 7.0 with 5D footage
  • log and transfer issues in FCP 7.0 with 5D footage
    Posted by Chad Tingle on November 1, 2010 at 8:26 pm
    I was recently transcoding some 5D footage from my hard drive using the log and transfer window I FCP 7. It all seemed to be working fine but I had to force quit to attend to something else that came up last minute. Now when I attempt to re-import the footage using the log and transfer, FCP does not recognize the footage. I’m attaching a sreen shot of the error message. It’s a file that is about 4GB in size.
    Chad Tingle
    Producer/Editor
    Caspian Brand replied 15 years, 11 months ago 3 Members · 2 Replies
  • Omar Itani
    November 2, 2010 at 4:21 am
    did you convert the footage before you imported it?
  • Caspian Brand
    November 4, 2010 at 6:31 am
    Are you importing the footage from a disk image of the original CF Card you shot on?
    or
    Did you copy it’s .MOV and .THM files to another hard drive?
    I’ve found that FCP and the EOS Plug-In prefer to look at a disk image. When offloading cards I will mount the CF card on the desktop, rename it something unique for that shooting session (akin to a tape name), then open Disk Utility and create a Compressed Image of the CF card on my media hard drive. This way when I run Log and Transfer, it sees the device it’s expecting and properly transcodes the files, adding the Time of Day Time Code stamps and so on.
    If you copied the files to a hard drive without creating a disk image of the CF card first, then you can trick it by first freeing up space on a CF Card, copying the directories and media files back, and then creating an image from the now full CF Card. Repeat the process for how ever many disk images you need to temporarily store all the media for imaging.
    -Caspian
