Activity Forums Apple Final Cut Pro Legacy Log and Transfer – how to import audio only?
  • Stephen Smith
    March 26, 2010 at 8:25 pm
    In the Log and Transfer window look where you give the clip a name and type the name of the reel. There are two buttons above that called Logging and the other is Import Settings. Click on the Import Settings and un check the video check box so you can only import audio. Best of luck.
    Utah Video Productions
    Check out my Motion Tutorials
  • Michael Peele
    March 26, 2010 at 9:24 pm
    I think you might also need to uncheck “Use clip settings” in the batch digitize window.
    Otherwise it will just redig with the video again.
