Activity › Forums › Panasonic Cameras › log and transfer from contents folder
  • John Fishback
    June 16, 2009 at 12:13 pm
    See Shane’s Stock Answer #38 https://library.creativecow.net/articles/ross_shane/fcp_faq3.php
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Jeremy Garchow
    June 16, 2009 at 1:21 pm
    You don’t necessarily need the lastclip.txt file. Are you having probelms logging and transferring?
    Jeremy
  • Danny Puckett
    June 16, 2009 at 9:00 pm
    It wasn’t the last clip text file I guess. But some weird things happened. When the footage log and transfered it cut all the clips at between 49 and 58 secs, the footage was slow, as if the frame rate was slow, and the audio was fine at first then it cuts out after around 30 secs. I tired 3 different computers. they all did the same thing. I tried the first computer again and it worked for some reason. Weird but im just glad i got the footage.
