Activity Forums Apple Final Cut Pro Legacy Log and Transfer corruption problem shuts final cut down.
  • Log and Transfer corruption problem shuts final cut down.
    Posted by Mehmet Caglayan on July 14, 2010 at 1:00 pm
    Hi Folks,
    I am working on a project where multiple external hard drives are at work. One has the footage in AVCHD and XDCAM the other has my project.
    I was using log and transfer and dumping all my files into one hard drive in PRORESS 422 HQ.
    One of the hard drives dismounted. I got the red dot warning indicating my hard drive was removed. It was not on my desktop nor it showed on the system. So I turned the computer off and re powered everything. Once all were back online. I tried to resume log and transfer. The clips played on the preview but when I drop them to Que it gave me a red dot waring and Final Cut shut down.
    Question Number 1: How do you completely erase final cut from your system? Because dropping into trash did not do the job. When I tried to re install final cut, the computer indicated I was upgrading and it did not ask me serial number and stuff.
    Question number 2: My imovie can transfer AVCHD files. So I know the files are not corrupt. Panasonic AVCHD Viewer also plays the files so I know the max os x is fine.
    DO I need to do complete system erase to get my final cut back to work?
    I can’t even get an error message to know what the heck is going on..
    Cheers
    Mehmet
    Mehmet Caglayan
    Blue Voyage Productions
    Savannah, GA
    Mehmet Caglayan replied 16 years, 2 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    July 14, 2010 at 3:30 pm
    [Mehmet caglayan] “Question Number 1: How do you completely erase final cut from your system? Because dropping into trash did not do the job. When I tried to re install final cut, the computer indicated I was upgrading and it did not ask me serial number and stuff. “
    FCS Remover:
    https://www.digitalrebellion.com/fcs_remover.htm
    [Mehmet caglayan] “DO I need to do complete system erase to get my final cut back to work?
    I can’t even get an error message to know what the heck is going on.. “
    Maybe, but don’t go there quite yet. Have you tried trashing the FCP prefs?
    What’s a ‘red dot warning’?
    Jeremy
  • Mehmet Caglayan
    July 14, 2010 at 7:43 pm
    Hi Jeremy thanks for the quick response.
    The red dot is:
    It looks like stop sign with exclamation mark in the middle.
    The only think I trashed was the final cut studio components in my application folder and I did clear my trash bin.
    But when I tried to re load the program it did not ask me the serial number and imidiatly went to installing as an upgrade…
    I will try your link first before I go nuts.
    Mehmet Caglayan
    Savannah, GA
  • Mehmet Caglayan
    July 28, 2010 at 12:27 am
    All is good.
    I reinstalled Final Cut and downloaded all the updates.. it is working fine.
    Mehmet Caglayan
    Savannah, GA
