Activity Forums Panasonic Cameras log and transfer challenges with HMC150p footage 1080p
  • log and transfer challenges with HMC150p footage 1080p
    Posted by Nic Beery on May 30, 2011 at 2:59 pm
    This is a question regarding my HMC150p camera.
    I am trying to log and transfer into my mac via FCP 7.0.3.(using a card reader and an SD card that is class 10)
    when in log and transfer, i try to select where i would like the footage to go and it gives me this message “”Project X” contains unsupported media or has an invalid directory structure. Please choose a folder whose directory structure matches supported media.”
    I never seemed to have this problem when importing 720 60i footage, but with this 1080 24p footage i am getting it.
    So, I imported it to the Hard Drive that it was set to previously on another project. worked fine and played back smoothly. Then I moved some of these imported clips to the hard drive I want to use for this particular project and the clips play very jerky.
    I am using 7200mps OWC external HDs, they have served me well with EX-1 and Canon HDSLR footage, all 1080p media.
    Anyone have suggestions? Thanks – Nic
    Nic Beery replied 15 years, 3 months ago 3 Members · 3 Replies
  • Sunny Jhooty
    May 30, 2011 at 4:38 pm
    for data protection you should always offload your card onto a hard drive and then log and transfer the clips. by doing the above it may also solve your current issue.
  • Noah Kadner
    May 30, 2011 at 7:08 pm
    I’d guess the hard drive you moved the footage to is either too full or is a 4200 RPM drive or USB. Either way it’s probably not up to the task. Try another drive. I use these with great success:
    G-Tech USB Mobile.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
  • Nic Beery
    May 31, 2011 at 7:48 pm
    Thanks for the input guys. I think it has been fixed.
