Activity Forums Apple Final Cut Pro Legacy Log and Transfer AVCHD video from Sony HDR-11
  • Log and Transfer AVCHD video from Sony HDR-11
    Posted by Arturo Celleri on July 6, 2009 at 6:18 pm
    I have captured footage on my Sony HDR-SR11 AVCHD camera and am using Log and Transfer in FCP 6.0
    After a clip is completely transferred, when I play it back the video has a hiccup in it. Every 2 to 3 seconds the video gets jagged like it’s going back a fraction of a second and then skipping forward.
    My sequence preset is : Apple ProRes 422 1920×1080 60i 48khz
    And my Capture preset is: HDV-Apple Pro Res 422
    The camera records 1920 x 1080 full HD.
    does anyone know why this is happening? The video does not behave the same when played back on the camera.
    I also want to know if there is a way to create SD DVD’s from this HD Source material on the AVCHD Camera?
    THanks,
    Andy Jolls replied 17 years ago 4 Members · 17 Replies
  • 17 Replies
  • Tom Wolsky
    July 6, 2009 at 7:44 pm
    Do you have Perian installed? It can cause a problem with this media.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Arturo Celleri
    July 6, 2009 at 8:46 pm
    Yes, I do have Perian installed. I’ll remove it and try to transfer again and see if makes a difference.
  • Arturo Celleri
    July 6, 2009 at 9:27 pm
    I removed Perian and it is still flickering after the transfer.
    Any other suggestions or resources that might help?
  • Tom Wolsky
    July 6, 2009 at 9:39 pm
    Exactly what version of FCP and of QuickTime are you using? What computer? What drive or drives? How is everything connected?
    All the best,
    Tom
  • Jeremy Garchow
    July 8, 2009 at 12:47 pm
    Open one of the Log and Transferred quicktime movies in Quicktime Player. See if it skips there.
    Jeremy
  • Arturo Celleri
    July 8, 2009 at 7:53 pm
    I opened it up in QuickTime and the same thing happened. I still have no answer and I’m here to work it out within the next few hours. I’d appreciate your help.
    I have a MacPro 2 x2.8 Ghz Quad-Core Intel Xeon, with 8GB 800 Mhz, , Running Mac OS X 10.5.6
    I have a G-Speedes (G-Raid) 4TB external disk that I am using as my Scratch Disk.
    My video camera is a Sony HDR-SR11
    I have Final Cut Pro 6.0.5
    Any other ideas?
    Thanks.
  • Jeremy Garchow
    July 8, 2009 at 7:58 pm
    Do you still have the footage on a card that you can playback form the camera? See if it’s on the camera as well.
    Jeremy
  • Arturo Celleri
    July 8, 2009 at 8:01 pm
    Thanks for the quick response Jeremy!
    I already checked the camera’s original footage and it does not behave this way.
  • Jeremy Garchow
    July 8, 2009 at 8:16 pm
    Hmm, must be something in the L&T process. Are you transferring form the card itself, or have you moved the contents of the card to another hard drive. I have never tried this from that camera, so I am just offering educated guesses here.
    Jeremy
  • Arturo Celleri
    July 8, 2009 at 8:23 pm
    I have done both. I copied the entire folder structure to my hard drive and tried to L&T from both the Hard Drive and the camera. I’m wondering having both available for the L&T is causing the problem. Any other ideas?
