Activity Forums Apple Final Cut Pro Legacy Log and transfer automatic volume mounting
  • Log and transfer automatic volume mounting
    Posted by Simon Cliche on August 9, 2012 at 7:41 pm
    Hi guys,
    We’re working on an external fiber volume (120Tb). When we add a “volume” in Log And Transfer from our fiber volume and forget to unmount it before closing Log and Transfer, the next time we open it, Log and Transfer try to mount previous opened volume and it takes years…
    Is there a way to “trash” the preferences of Log And Transfer so he forget the previous mounted volume?
    We’ve tried to trash FCP prefs, but it’s not the solution…
    Simon
    Simon Cliche replied 14 years ago 2 Members · 2 Replies
  • Shane Ross
    August 9, 2012 at 7:48 pm
    When you are done logging and transfering, EJECT the tapeless media from the L&T interface. DO NOT PRESS THE DELETE KEY! This will actually DELETE your footage. YOu get a nice warning, so heed that. No, there is an eject button on the top of the interface. Select one clip, press EJECT. Done.
    Shane
    Little Frog Post
  • Simon Cliche
    August 10, 2012 at 2:07 pm
    You’re right, and I know that we have to eject the volume before quitting Log and transfer, but since I’m not the editor/assistant, I’m in charge of 10 FCP stations and it happens on each because people (freelancers) forget to eject…
    That’s why I’m trying to find a way to manually reset Log and transfer before launching it.
