Activity Forums Apple Final Cut Pro Legacy Log and Transfer AC3 Settings
  • Log and Transfer AC3 Settings
    Posted by Jason Watkins on June 17, 2010 at 12:13 am
    Anyone know the difference between the Log and Transfer AC3 settings: Matrix vs Plain Stereo? I have searched around and the best thing I found is from Apple:
    Note: When ingesting AVCHD audio, the AVCHD plug-in is preset to ingest the audio as Matrix stereo. With some AVCHD camcorders, the audio may sound unbalanced when ingested as Matrix stereo. To correct the imbalance, select the AC-3 Audio decoder option in the AVCHD plug-in preferences, and choose Plain Stereo. Then reingest the AVCHD footage. It’s a good idea to ingest an initial AVCHD clip and check for this sound imbalance. You can then select the appropriate setting before ingesting the remainder of your AVCHD footage.
    I transferred the same clip to do a comparison and didn’t hear a difference. I am kind of confused about their use of the word unbalanced, as that can mean different things in the audio world. Any help is appreciated, thanks.
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 17, 2010 at 1:53 pm
    Sounds to me that they are talking about levels recorded the same, but coming in a a different levels – unbalanced that way.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
