Activity Forums Apple Final Cut Pro Legacy Log and capture register’s TC but not SDI signal
  • Log and capture register’s TC but not SDI signal
    Posted by Ciller on October 11, 2006 at 10:08 pm
    Im using an AJA Kona card to capture Digibeta footage from a Sony J3 deck ive never had a problem before but when i open log and capture in any of my easy setup’s i get green lines on the display and one vertical white line on my video monitor!
    VTR is OK and i do have control of the deck but the SDI signal just doesnt seem to be getting threw?
    However i was digitising with this same system yesterday with no problems at all??
    is this a glitch or have i changed one of the KONA settings without realising?
    Any help would be great cause im baffled!
    Slan
    Ciller
    Ben Insler replied 19 years, 11 months ago 2 Members · 1 Reply
  • Ben Insler
    October 11, 2006 at 10:49 pm
    Probably changed your Kona Settings, or more accurately your capture settings in FCP (which controls the Kona when FCP is open). Make sure the Capture/Input in your Log and Capture settings is set to a DigiBeta-compatable input (as in “AJA Kona3: 525 29.97 8 Bit)
